richard400 Posted February 19, 2009 Share Posted February 19, 2009 Hi I'm replacing the bar clamps on a 2006 250TXT. There's no access to the rear bolt in the existing clamps as the hinge is in the way. How do I get the hinge pin out? Drive it out? Or is there some other fiendish way of getting the existing clamps off? Thanks Richard Quote Link to comment Share on other sites More sharing options...
jse Posted February 19, 2009 Share Posted February 19, 2009 HiI'm replacing the bar clamps on a 2006 250TXT. There's no access to the rear bolt in the existing clamps as the hinge is in the way. How do I get the hinge pin out? Drive it out? Or is there some other fiendish way of getting the existing clamps off? Thanks Richard Richard, If they are like the standard clamshell clamps, undo the front capscrews, take off the bars and you'll see the other two short capscrews under where the bars go. Jon Quote Link to comment Share on other sites More sharing options...
laser1 Posted February 20, 2009 Share Posted February 20, 2009 I drive the pins out. The trick is not ending up with the pins on the floor and spending the next hour looking for it. Quote Link to comment Share on other sites More sharing options...
