krazydayz Posted March 24, 2009 Share Posted March 24, 2009 bought a new plug today, old plug was grey/white and also the wrong size. 100ml 2-stroke to 5ltr fuel.. (100ml to green fuel can) what adjustments do i need to make? Quote Link to comment Share on other sites More sharing options...
stork955 Posted March 24, 2009 Share Posted March 24, 2009 Gday, If it was the wrong size ( I assume the wrong length ) I'd run it for a little while and have another look before changing anything else. Was it running OK? Cheers, Stork Quote Link to comment Share on other sites More sharing options...
krazydayz Posted March 24, 2009 Author Share Posted March 24, 2009 Its running and starting fine. But it spits its dummy out at high rpm. Old plug was to long and cheap. Was leaking oil through the the thread. Quote Link to comment Share on other sites More sharing options...
laser1 Posted March 25, 2009 Share Posted March 25, 2009 Whats the new plug look like? (what plug are you using?) If white, then re-jet. Here the starting point for the US based bikes. UK may be a tad richer. Ask a local dealer/rider what they run. From the Trialsp[artsUSA site: 1998/99 TX270 2000/01/02/03 TXT280, TXT280,TXT321, TXT280 Quote Link to comment Share on other sites More sharing options...
krazydayz Posted March 29, 2009 Author Share Posted March 29, 2009 new plug is black, the thread is liqued oil. Quote Link to comment Share on other sites More sharing options...
laser1 Posted March 29, 2009 Share Posted March 29, 2009 what jetting are you running??? You mentioned an old plug that was wrong, and a new plug. What plug are you now using? What Gap? Quote Link to comment Share on other sites More sharing options...
