Beta 80
dickiem
Hi, just got hold of an '03 Beta 80 for my son, what a cracking bike :dunce:
Just a couple of minor niggles:
1) It appears to seep oil from the seal around the output shaft (the one the gearbox sprocket is fixed to). Any ideas how big a job it is to fix and where to get a replacement seal from?
2) One of the fork seals is leaking slightly, how big a job is that to change?
Edited by dickiem
from memory both jobs are relatively easy, especially fork seals. the easiest place to get both seals are from Lampkins as i remember the fork seals are slightly unusual either 10 or 11mm thick although you can get away with a thinner standard seal, but lampkins are reasonably priced anyway
