davet Posted May 4, 2009 Share Posted May 4, 2009 My exhaust muffler has split where the tyre rubs,is there a way to repair this problem with a kit or will i have to have a plate welded ? Any suggestions out there. cheers Dave Quote Link to comment Share on other sites More sharing options...
jse Posted May 4, 2009 Share Posted May 4, 2009 My exhaust muffler has split where the tyre rubs,is there a way to repair this problem with a kit or will i have to have a plate welded ?Any suggestions out there. cheers Dave I'm assuming you mean that the tire has rubbed through the metal and you don't have an actual "split", which could easily be welded. Any good welder will be able to cut out a square and TIG in a patch plate. Be sure to check the muffler after your next shunt to be sure it was not pushed in and is rubbing on the tire. Dirt on the tire acts as a grinding compound and quickly wears the metal. Jon Quote Link to comment Share on other sites More sharing options...
