May 17, 200917 yr Hi Guys, can anybody tell me the size/code for a `04 280 Pro front wheel bearings, are they the same as the back which is 6004 2RS. Thanks in advance.
May 17, 200917 yr Might be worth having a look at your front wheel, if it has a large axel then no.. you would need 6905 2rs.. If not, then you would need 6004 2rs. same size as rear... Hope this helps.
