August 8, 200917 yr Eh op all Can anybody out there give me tips on how to bounce front & rear wheel. So i can face the other way in tight spots. I can raise both wheels but cant swing bike left or right , it just drops down near enough in same place . So any tips gratefully recieved.... Cheers ave one on me.
August 8, 200917 yr Author sorry for this question just found similar question posted earlier, and there is plenty of tips, so i will practice , practice, and hopefully crack it.
August 8, 200917 yr sorry for this question just found similar question posted earlier, and there is plenty of tips, so i will practice , practice, and hopefully crack it. Yo, I posted up a thread about this a whie ago, "Turning in tight spaces" i think it was called, there is some good advise there, But tbh i think its just ptactice mate
August 10, 200917 yr Pull up on the inside handle grip (in the direction that you want the front end to go, when doing a front-end hop.) Really helped my brother.
August 16, 200917 yr Out experimenting today. Sometimes a FLOATER turn (front wheel in the air, since it's so tight) is a good option to consider. The trick I keep finding (and Ryan Young's video says this for sure) is to STAB down on the INSIDE foot peg! Put all your weight on that inside peg, for just a second, in a violent motion. The difference is amazing.
September 18, 200917 yr I've likely mentioned before how I'm able to turn tighter now since on my '08 GasGas I removed that rubber turning-stop that's against the frame. I put a small piece of tape to (well, somewhat) keep where the fork-brace HITS the frame (now that that rubber turn-stop has been removed) from chipping the paint on the frame. It's worth it. The most experienced rider in the US National series uses that technique, and I like it. One of my riding partners balked at doing this, however.
