jsygasgas Posted November 24, 2009 Report Share Posted November 24, 2009 (edited) HI My 2008 gasgas 125 wont change up from gear 2 to gear 3 all the other changes are fine i can do it if i stall the engine and change it by hand obviously not much good in the middle of a section was told that it was some kind of cap that might have broke under the clutch plates but checked it and it was fine ?:S ............ When i try and change up with my foot the leavers just moves up as normal but no change PLEASE HELP Edited November 24, 2009 by jsygasgas Quote Link to comment Share on other sites More sharing options...
lowbrow Posted November 24, 2009 Report Share Posted November 24, 2009 Have you thumped your gear lever on a rock? I think you'll find you've broken one of the spring loaded ratchet arms that rotate the selector drum. If i'm right it's a motor out, split the crankcases job I'm afraid. Quote Link to comment Share on other sites More sharing options...
jandyb Posted November 24, 2009 Report Share Posted November 24, 2009 HI My 2008 gasgas 125 wont change up from gear 2 to gear 3 all the other changes are fine i can do it if i stall the engine and change it by hand obviously not much good in the middle of a section was told that it was some kind of cap that might have broke under the clutch plates but checked it and it was fine ?:S ............ When i try and change up with my foot the leavers just moves up as normal but no change PLEASE HELP Hi Check out this video from about 6.30. http://www.youtube.com/watch?v=A80n7zq80n8 Does this help? -Jan Quote Link to comment Share on other sites More sharing options...
