February 8, 201016 yr I recently purchased a Rev3 2002 and initially it started very easy,Ileft the bike without starting it for about 4 weeks and now find it will not start. Fitted a new plug today and with the coldstart plunger up managed to get it started and run for about 10seconds, after that it will only start after several kicks and run for about 2-3 secs. It sounds like fuel any idea's guys?, thanks in anticipation
February 8, 201016 yr Gday, yes, it sounds like fuel. I'd clean the carb and refill the tank with fresh fuel. While you're at it, check and clean the air filter as well. Cheers, Stork
February 8, 201016 yr Author I'll try that on my next day off another thing it did run out of petrol,maybe its dragged rubbish into the line/carb
February 8, 201016 yr When ever i get anew bike i always add an in line fuel filter, they are a must.
February 13, 201016 yr Author ALL sorted float valve stuck, washed out probably a small piece of grit jamming the valve starts 1st/2nd kick, happy now.
