squid Posted February 17, 2010 Share Posted February 17, 2010 Hello. Me sump nut is totally rounded. Iam stumped again. I cant get anything in that diddy hole to grip it. Has anyone got any tricks. Squid. Quote Link to comment Share on other sites More sharing options...
andy.t Posted February 17, 2010 Share Posted February 17, 2010 If you take the sump guard off then you wont have to get into the diddy hole, then perhaps you can grip it with some mole grips. Quote Link to comment Share on other sites More sharing options...
squid Posted February 17, 2010 Author Share Posted February 17, 2010 Hello Andy T I thought about that but couldn't get a spanner between the gap to hold the nut. I thought, surely I dont have to take the engine out to get the belly plate off. Squid. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 17, 2010 Share Posted February 17, 2010 Hello Andy TI thought about that but couldn't get a spanner between the gap to hold the nut. I thought, surely I dont have to take the engine out to get the belly plate off. Squid. The nut is usually captive, ie fixed to the fame and does'nt need to be held. Quote Link to comment Share on other sites More sharing options...
squid Posted February 17, 2010 Author Share Posted February 17, 2010 Thanks B40RT. I've been turning it like a mad man,but its just spinning and not coming out. I guess I just cant top up with fresh oil as I dont know what the guy used to put in there before I bought it,or can I? Sorry for all these lame mails, but I've no previous experince with mechanical things and I'd just like to do it properly. Its so good having all you lads out there to guide me. Much appreciated, for all your Knowledge. Cheers. Squid. Quote Link to comment Share on other sites More sharing options...
andy.t Posted February 17, 2010 Share Posted February 17, 2010 If its one of the nuts on the front near the exhaust, its possible to get something down there to lock the nut, if its one near the back of the engine then they dont look so easy. I would hold the head of the bolt and drill out the head, then you could either get the nut bit re welded or get some captive type nuts. Quote Link to comment Share on other sites More sharing options...
richty250e Posted February 17, 2010 Share Posted February 17, 2010 Hello Squid, You may be able to squeeze in a cycle spanner, they are usually much thinner than 'normal'. You'll need a 14mm open end spanner to fit the standard square weld nut. Quote Link to comment Share on other sites More sharing options...
tony283 Posted February 17, 2010 Share Posted February 17, 2010 Squid, You don't say whether its the normally welded flat nut on the inside on the bracket or the bolt is just spinning and not moving in or out? In my experience the nuts don't normally break away from the weld and its more likely that someone has cross threaded the bolts at an angle when replacing the shield. If this is the case remove the "good" 3 bolts then use the shield itself as a pressure lever as you unscrew the offending bolt. Tony Quote Link to comment Share on other sites More sharing options...
squid Posted February 18, 2010 Author Share Posted February 18, 2010 Thanks Andy T, Rich TY250E and Tony for your help. The flat nut on the insides not spinning and the bolts not moving in or out when Iam spannering. Not one of the 4 is behaving properly, Iam almost in tears. I didn't think I'd have to ask for help on removing a belly, bash plate thing. What a to do. Cheers Squid. Quote Link to comment Share on other sites More sharing options...
blocky Posted February 18, 2010 Share Posted February 18, 2010 Get out an angle grinder and grind off the bolt heads so that you can remove the sump guard. Having removed it you should now be able to decide on a plan of action to sort out the problem once and for all. Quote Link to comment Share on other sites More sharing options...
squid Posted February 18, 2010 Author Share Posted February 18, 2010 Hello Blocky. Yes that logical but I guess I'd set me bike alight with the sparks. Thanks anyway. Squid. Quote Link to comment Share on other sites More sharing options...
squid Posted February 18, 2010 Author Share Posted February 18, 2010 In total desperation I wheeled me bike round to the local garage. The guy had a spanner with more faces than the one I had and gripped me sump plug. Sorry for me mincing mails but I've now changed the oil. It was brown muck that came out. Whats that a sign of. Hope its not naughty as I planning on taking her out tomorrow to get muddy in the hills. Please I didn't mean to waste your time, you've given me more knowledge and Iam learning. Cheers Squid. Quote Link to comment Share on other sites More sharing options...
andy.t Posted February 18, 2010 Share Posted February 18, 2010 Brown muck should be fine, I would give it another oil change fairly soon as whats in there now will probably get dirty quickly. Quote Link to comment Share on other sites More sharing options...
squid Posted February 18, 2010 Author Share Posted February 18, 2010 Thanks Andy T. I'll do that. Looking forward to getting dirty tomorrow. Hopefully I wont have to write another mail tomorow night when I get in. Cheers. Bon Nuit. Squid. Quote Link to comment Share on other sites More sharing options...
