rodt Posted March 17, 2010 Share Posted March 17, 2010 Good Evening. I have a Scorpa SY 125. Has a IRC winner Tubeless tyre on the rear with a tube. It has one security bolt. Will this be enough? Also is there a mod for the rear brake pedal to stop it tangling with the Kickstarter? Any help would be appreciated. Thankyou Quote Link to comment Share on other sites More sharing options...
4stroke Posted March 17, 2010 Share Posted March 17, 2010 You will need two bolts on the rear and one on the front to stop the tyres creeping. I seem to remember adding extra security bolts to the little scorpa I had. Quote Link to comment Share on other sites More sharing options...
rodt Posted March 17, 2010 Author Share Posted March 17, 2010 You will need two bolts on the rear and one on the front to stop the tyres creeping. I seem to remember adding extra security bolts to the little scorpa I had. Thankyou for your help, 4stroke Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 18, 2010 Share Posted March 18, 2010 You will need two bolts on the rear and one on the front to stop the tyres creeping. I seem to remember adding extra security bolts to the little scorpa I had. This will minimise tyre creep, you will still have to let tyres down and pull them back occasionally, particularly the back. Quote Link to comment Share on other sites More sharing options...
rodt Posted March 18, 2010 Author Share Posted March 18, 2010 This will minimise tyre creep, you will still have to let tyres down and pull them back occasionally, particularly the back. Thankyou B40. always had two in the rear years ago,Bultaco and Fantic. Even had two in Pre 65 Bantam. I was thinking it might be different with a tubeless tyre on a tubeless rim. I'll have to fit another one in the back Quote Link to comment Share on other sites More sharing options...
