June 12, 201016 yr It seems I've rounded the bolt that holds the pads in is there an easy way to get this bolt out ? If was in mega tight though Also, how much should a set of front pads cost me ??
June 13, 201016 yr Try driving a torx bit of proper size into the rounded allen head. Usually does the trick unless you screw it up totally, then the drill points!
June 13, 201016 yr Author Also, how much should a set of front pads cost me ?? rear pads are no more than
June 15, 201016 yr simple enough...... Yes I think he is. Stuart, your PM mailbox is full. Can you empty it so I can PM you. Edited June 15, 201016 yr by bigfoot
