cabby Posted June 12, 2010 Share Posted June 12, 2010 It seems I've rounded the bolt that holds the pads in is there an easy way to get this bolt out ? If was in mega tight though Also, how much should a set of front pads cost me ?? Quote Link to comment Share on other sites More sharing options...
shercofray Posted June 12, 2010 Share Posted June 12, 2010 rear pads are no more than Quote Link to comment Share on other sites More sharing options...
copemech Posted June 13, 2010 Share Posted June 13, 2010 Try driving a torx bit of proper size into the rounded allen head. Usually does the trick unless you screw it up totally, then the drill points! Quote Link to comment Share on other sites More sharing options...
cabby Posted June 13, 2010 Author Share Posted June 13, 2010 Also, how much should a set of front pads cost me ?? rear pads are no more than Quote Link to comment Share on other sites More sharing options...
ukmarra Posted June 14, 2010 Share Posted June 14, 2010 I just ordered front pads from eBay for my 07 sy for Quote Link to comment Share on other sites More sharing options...
cabby Posted June 14, 2010 Author Share Posted June 14, 2010 I just ordered front pads from eBay for my 07 sy for Quote Link to comment Share on other sites More sharing options...
tt5th Posted June 15, 2010 Share Posted June 15, 2010 Just type "scorpa brake" into ebay, simple enough...... Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 15, 2010 Share Posted June 15, 2010 (edited) simple enough...... Yes I think he is. Stuart, your PM mailbox is full. Can you empty it so I can PM you. Edited June 15, 2010 by bigfoot Quote Link to comment Share on other sites More sharing options...
