June 17, 201016 yr I'm thinking of buying a Toyota Rav 4 (51 reg). I would also like to use this vehicle so that I can transport my Sherco 250 (2008 model) on the back using a standard (DC) trials motorcycle rack which I have used on a previous 4x4. My concern after viewing a Rav 4 was that the spare wheel which is located on the back door seems to protrude a heck of a lot and could well snag the gear shift/LHS of the bike. Does anyone else use a Rav 4 to carry a trials bike in this fashion?
June 18, 201016 yr Either throw the spare wheel in the back of the car; or get Dave Cooper's rack with extended arms to give you enough clearance from it. The bike/rack combo moves more, which can be a bit alarming when you look in the mirror, but otherwise it works well on my Honda CRV. DC's standard rack put the bike a touch too close to the spare and I realised that adding in movement as you go down the road meant that the bike was bound to get a bit of damage by jouney's end. I reckoned it was better to lash out on a new rack than arrive at a trial brimming with expectation and find the bike was now unfit to ride.
June 18, 201016 yr get your local blacksmith to extend the rack its only a 15 min job .a lot cheaper than buying a new one
June 18, 201016 yr You can buy aluminium spacers to put behind your towbar from caravan type places, they're about 3/4'' thick, you'll need longer bolts too. 3/4'' doesn't sound much but it did make a difference. I also put an old rear tyre from my bike between the bike and spare car wheel.
June 18, 201016 yr Author Dear All Thanks for the advice, sounds as though there are a few solutions to this. Cheers
August 3, 201016 yr Prefer the Toyota FJ40, I got a piece of 5mm x 125mm Aluminium channel bolted directly to the rear of the chassis, bike sits high and proud. 6 cylinder 4.2 litre petrol is a bit thirsty tho good luck with the Rav 4, Kevo
