Searching For Beta Rev 3 Bolt Torque Tension Scedule.
luct4
had a file with these in, think i may have copied it from a previous post
Tightening torque Rev3:
Shock absorber-Swingarm 45Nm
Shock absorber-Frame 45Nm
Connecting frame rod-frame 23 Nm
Cylinder-Crankcase 20-23 Nm
Primary drive gear 120 Nm
Handlebar 25 Nm
Engine-frame 50 Nm
Swingarm bolt 90 Nm
Front wheel axle 65 Nm
Rear wheel axle 65 Nm
Steering stern bracket 25 Nm
Rear fender bracket 10-15 Nm
Front brake pad 20-23 Nm
Rear brake pad 20-23 Nm
Engine Head-Cylinder nuts 15-16 Nm
Front axle fixing nuts 10 Nm
Flywheel 140 Nm
As for a schedule, if they're loose tighten them.
