Hebo Auxillary Tank
Hi Guys,
Just fitting one of thhese Hebo tanks to the front of the bike and the instructions (or me) are not to clear.
I take it the pipe that has a small tube inside the tank whoch sits on the bottom connects to the vent tube from the fiiler cap and that the other pipe which has a plastic vent type top just hangs in the open?
Does it really manage to syphon from the Hebo tank into the bike tank OK?
Yes - that is correct :agreed:
The system works fine if you have sufficient fuel in the tank of the bike itself to begin with as thats what the syphon relies on.
The bike will draw a little from the main tank - begin the syphon, then use the auxillary tank - then your own tank... If that makes sense? So dont be surprised to see the auxillary tank level dropping first :beer:
Thanks. will see if its usefull at the weekend.
