Where's My Spark Gone?
nicbrrghs
The bike started running erratically and lacking any power eventually dieing with no spark at all.
I have changed the coil pack and still only sparks intermittently, on pulling the side cover of the left of the bike I noticed a lack of a gasket and that a lot of crap/dirt had got in.l
Could this be the cause or does anyone know better?
Got one of the lambretta coil packs of ebay on advice from a forum seems okay. I have a yellow wire which isnt connected to anything at the moment.
What size flywheel puller do i need i have already got quite a collection but not small enough for this.
Thanks in advance for any help or advice.
I have just had trouble with my rc mag misfire - not revving , but i replaced the wiring from the mag to the cdi with heat resistant cables and also found the external pick up was loose and corroded between the stator AND PICK UP . I tried the bike out last night and what a difference the bloody thing fly, now . I add my 125 has dansi electronic ignition with a solid plastic source coil , but my trials has a wound coil that i read can play up BUT A REWIND SHOULD FIX THE PROBLEM
Edited by caballero125
