broony Posted September 9, 2010 Share Posted September 9, 2010 Looking for a wee bit help please.Building a D7 trials bike.Nearly finished it but when out testing it in the field next to the house the bike pulls well from the bottom end but goes off at the top end(looses power/flat).It is fitted with a 22mm Amal concentric carb and the std. pan cake filter(not the one with the strangler).I'm not looking for an instant cure but a wee point in the right direction would be braw i.e. jetting??? cheers the noo Brian P.s. the carb is brand new Quote Link to comment Share on other sites More sharing options...
3896 Posted April 27, 2011 Share Posted April 27, 2011 Give it a bit more jucie on side big screw is Rickover and other is fuel air screw it in a bit more Quote Link to comment Share on other sites More sharing options...
alan_nc Posted April 28, 2011 Share Posted April 28, 2011 Run it without the air cleaner - just long enough to see if it is restricting the air flow. I had a real problem with that on mine. Quote Link to comment Share on other sites More sharing options...
harry185 Posted March 4, 2012 Share Posted March 4, 2012 Put a 26mm carb on put a 170 main jet in and a 30 pilot jet Quote Link to comment Share on other sites More sharing options...
