September 10, 201015 yr Has anyone a table or list of torque setting for the various crank case, clutch and magneto nuts & bolts on a 247cc Cota please
September 18, 201015 yr Pertinent specs for the Cota 247 are as follows: Cylinder bolts - 18 lbs ft Cylinder head nuts - 25 lbs ft Flywheel - 72 lbs ft Primary drive flywheel - 72 lbs ft Not a torque, but ignition timing is: Before serial number 21M3000 - 4.00 mm (0.157 inch) After serial number 21M2999 - 2.50 mm (0.098 inch) Edited September 18, 201015 yr by nh014
