01 rev 3 suspension setup
betanz
Most of the jumping comes from technique rather than suspension settings...... if you have the suspension too soft and bouncy you will loose traction on the slippy stuff.
Saying that start by checking you only have 1/3 sag at both front and rear when you stand on the bike. Adjust the springs until it is correct. Then adjust the rebound damping to just slow the stupid fast spring action.
