2010 front suspension oil change
hannu
I had this problem recently when replacing a fork seal. If you put the lower fork leg in a vice and pull on the stanchion as you're unwinding the bolt it should come out. Hope that helps.
Thanks for that but I have just found something more worrying. The bolts at the bottom of the forks are different sizes the larger one being the Left side I cant get out. I am starting to think that someone has stripped the thread and shoved a larger bolt in !!! <_<
Ah, looks like they should be different sizes even though the parts manual states they are the same !!! it just needed a quick buzz with a windy gun !!. Job done :D
