November 15, 201016 yr Hi, all new to the forum, ive just bought a ty 250 trials bike dont now the year, but i think it needs new clutch friction plates as the bite is right at the end and sometimes its not going into gear if changing fast if you take your time it goes in fine? Just wondering if its an easy job and the cost? Thanks,
November 15, 201016 yr Ty 125,TY 175,TY 250,YZ 125 and XJ 550,XJ 650 are all the same plates. Chrs:Mike
November 15, 201016 yr Author Ty 125,TY 175,TY 250,YZ 125 and XJ 550,XJ 650 are all the same plates. Chrs:Mike Hi, thanks for the reply do you know if they are easy to change? THANKS
November 15, 201016 yr Very easy. Drain the gearbox oil remove the kickstarter from the shaft Remove all bolts from the Clutchcase Remove the srews from the clutchbottomplate change the plates. Then reverse order together Put a new gasket between crankase and clutchcover. Chrs:Mike
November 15, 201016 yr Soak the new plates in oil before you fit them, the same oil you will be using in the gearbox..
November 15, 201016 yr Author hi, thanks for the replies guys, think ill have to do it soon as it is getting harder to get in gear, What oil do you suggest using nothing special tho, just tidy stuff? Thanks,
November 16, 201016 yr hi, thanks for the replies guys, think ill have to do it soon as it is getting harder to get in gear, What oil do you suggest using nothing special tho, just tidy stuff? Thanks, Normal 80 or 90 gerabox oil from any brand. Chrs:Mike
November 16, 201016 yr I've been using Land Rover MTF94 (Manual transmission fluid) for the last couple of years,about
