vmeldrew Posted November 27, 2010 Report Share Posted November 27, 2010 Hi I am in the process of changing the front springs in my TXT 300 pro 2007. Without the springs on I put the right (sitting on the bike and has a red cap) cartridge in and did up the drain bolt which I assume attaches to the cartridge, without any problem. I came to do the left side and I cannot get the bolt to locate into the cartridge. If I use a longer bolt I can get the thread started. I looked inside and there is what looks like a washer or spacer sitting in the bottom of the fork, which of course doesnt want to come out. I really dont want to be taking the forks off the bike if I can get away with it as its -3c in my garage and I was hoping to do a trial tomorrow. Question is, do I try and get it out, or keep fiddling with the bolt? and should it actually be there? I have looked at some exploded diagrams and none of them show a washer or spacer below the cartridge. Cold and desperate. Al Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 27, 2010 Report Share Posted November 27, 2010 Yes there is a spacer in the bottom. It is probably turned upside down , remove the fork and put it back in. Hope it goes togetherso you ride tommorrow. Quote Link to comment Share on other sites More sharing options...
vmeldrew Posted November 28, 2010 Author Report Share Posted November 28, 2010 Yes there is a spacer in the bottom. It is probably turned upside down , remove the fork and put it back in. Hope it goes togetherso you ride tommorrow. Lineaway Thanks a million, that did the trick. How the hell it got turned upside down I will never know. Anyway off to load the van! All the Best Al Quote Link to comment Share on other sites More sharing options...
