XL125 head on a TL125
showtime45
Would there be any advantage to putting a XL125 head with the larger valves on a TL125 ?
Hello showtime45
I have a couple of TLs and have found that the Miller 150cc kit has a very thin spigot and although I have had one sitting in my shed for some ten years I am wary of using it because of spigot failure/cracks, however if you are using the bike for twinshock trials it should be ok,
Bigger valves would help the bike to rev higher but would rob it of some torque in the lower rev range.
Regards Rocker1
The XL head has a combustion chamber volume of 15cc (measured by myself) as compared to 12cc (from info on the net) for the TL. If you fitted the XL head with the standard TL dished piston (the XL has a domed piston) the comp ratio would go down by about 1.5 points. The TL has a low ratio to start with so I think it would make it too flat.
And as mentioned, bigger valves also rob the engine of low down torque.
