December 22, 201015 yr Hi all, Just bought a 2007 250 rev 3 can anyone advise what gear oil to use and what ratio to run the fuel at and is there a easy way to work it out prob a stupid question. Adam
December 22, 201015 yr Hi, pour 80ml of oil into a measuring jug, then pour that into a can of fuel with 5litres of super unleaded, shake it up a bit and pour into bike. You can use either a light gear oil or atf in your gear box. Good luck with your new bike. p.s. make sure you use a fully synthetic oil like castrol tts or similar. cheers
December 22, 201015 yr Hi As Adam1 said...Castrol TTS is great (i run at 75mls to 5 ltrs of super unleaded) A good gear oil like putoline GP10 should be more than good enough. Some info below....Cheers http://www.betatrialuk.com/content/view/50/51/
December 22, 201015 yr Author Thanks for the quick response chaps, i have been reccomended PJ1 fully synthetic as this is what the local bike shop sells is this any good. Also can anyone reccomend a good quality grafix kit too! chers Adam
December 22, 201015 yr Hi Adam Hi steve saunders site.. http://www.saundersextremesports.co.uk/product.php?id=1254855093&parent=115 or http://www.stormgrafix.co.uk/ Never used PJ1 in any of my bikes so cannot comment...always used putoline Cheers
December 23, 201015 yr Author Hi Adam Hi steve saunders site.. http://www.saundersextremesports.co.uk/product.php?id=1254855093&parent=115 or http://www.stormgrafix.co.uk/ Never used PJ1 in any of my bikes so cannot comment...always used putoline Cheers Cheers for that had a look at steve Saunders site fancy the ttt graffix kit
December 24, 201015 yr Hi adam Use the ATF II in the gear box and change it often - say every 10 trials events - it is cheap enough and works really well in the Beta's. If you are keen do the clutch modification at the top of the Beta forum. I used to use fully synthetic 2 stroke oil at 70:1 - Hunt out the Putoline Trials it is good stuff.
December 24, 201015 yr Author Hi adam Use the ATF II in the gear box and change it often - say every 10 trials events - it is cheap enough and works really well in the Beta's. If you are keen do the clutch modification at the top of the Beta forum. I used to use fully synthetic 2 stroke oil at 70:1 - Hunt out the Putoline Trials it is good stuff. Hi mate without sounding thick what does this mod fix? as i havent been on my bike yet and i am new to trials bikes Adam
December 28, 201015 yr Author Picked up my trials bike today, had a quick play out as the weather still quite bad but on first impressions i like it! Adam
December 28, 201015 yr Use the ATF II in the gear box and change it often - say every 10 trials events Every ten trials I change my oil every 3 trials, am I over doing it then ???
December 28, 201015 yr For gearbox oil I would ask Steve Saunders, there is a good oil (I cant remember the brand) that he recommends if you have a bit of a sticky clutch. I would inspect the oil in the level window ) if your bike has one, it is easy to spot if it has changed colour or looks contaminated, on my 200 I once changed it after only 2 trials that were very wet as it looked slightly milky. Edited December 28, 201015 yr by grindrod
