December 30, 201015 yr hi all got a rev 3 125 had a problem a while back not running right after checkin everything else it was just old fuel in the tank DOH got a new prob ,riding it today when i heard somthing rattling in the flywheel casing,opened it up and two little screw heads were in there ,you know the 4 screws on the face of the flywheel 2 had sheared off ,any one had this happen ?
December 30, 201015 yr Hi Jackbeta125 I would imagine you can just take the other two out unless they have rusted in position and just take the flywheel weight off . Other wise you will need to drill and use an easyout to remove them like in linky. ( http://www.axminster.co.uk/axminster-cobalt-drill-and-easy-out-set-prod462398/ ) Cheers
December 31, 201015 yr I read here that if you remove the four screws and change the factory indexing of the relationship of the magnetes to the holes the generator will not work correct anymore. It may be a good idea to mark the parts for position.
December 31, 201015 yr Author I read here that if you remove the four screws and change the factory indexing of the relationship of the magnetes to the holes the generator will not work correct anymore. It may be a good idea to mark the parts for position. thanks fellas for the info ,will mark them up never crossed my mind that cheers
