Cota 348 Clutch Removal
sunny
How do you break the clutch apart? Is there a sercret to compressing the clutch to pull the pins? Or does it come off as a unit?
P.S.
Is there a workshop manual for the Montesa? I have the Haynes and Clinton for my Bultaco's but I can not find anything more than the parts diagram for the Cota 348
Sunny
It comes off as a unit... loosen the nut after flattening the tab washer, then pull on the whole unit with one hand, both if you have a helper, and tap on the nut squarely with a "dead blow" hammer. (plastic, filled with lead). Be patient...
When it pops off, there's 3 locating dowels an 2 different flat washers that you'll need to catch. Remember the order of the flat washers.
The spacer (more like a thrust washer) is located between the inner clutch basket and the inner side case. If you have access to a part diagram, as you have indicated, it is part number 0263.126.
