rev3 timing setup (4 coil)
Rich,
Not to change your subject, but can you tell which ignition is on your bike? Is it Leonelli, Ducati?,Other?
In something of an answer to your question, are there witness marks on your stator, or the old one? Seems for the most part a mm or so makes little to no difference, err to the slow side.
Cheers
Hi
Not sure what make it is?
I set my mate 2004 up as the picture says seems much better, but just thought someone else may no for definite.
as i need to set up a 2008 now.
  • 11 years later...
I know this is an old thread but did you ever figure it out? I have an '06 Rev 3 (4 coil) that I just changed the stator on and I'm having trouble narrowing down the timing.
