June 30, 201115 yr Any body know the model number for the rev 4t Mikuni Carb so i can get some spares even lampkins dont know it !!!!! Edited June 30, 201115 yr by neilnh
July 7, 201115 yr Any body know the model number for the rev 4t Mikuni Carb so i can get some spares even lampkins dont know it !!!!! Mikuni make many OEM variations on that CV carb. Never could find the exact model number myself, when looking. But, I finally did figure out that it is the same as on the Yamaha Raptor 660 (it uses two), so I was able to buy spares, and jets, from the Yamaha dealer.
July 9, 201115 yr I recall it is a Mikuni 28mm BSR SE.... and yes as per the above Yamaha use 'em They are sent out lean in the mid range to pass emissions testing.... so....raise the needle most of the way up and approx 2.5 turns out for the mixture Edited July 9, 201115 yr by NZRalphy
July 19, 201115 yr Author thanks for your replies chaps will now have a word with my local yamaha dealer to see if he can supply any bits i need
July 21, 201115 yr thanks for your replies chaps will now have a word with my local yamaha dealer to see if he can supply any bits i need Without sounding daft where is the ar mix screw located on the carb? it doesnt seem that apparent
July 21, 201115 yr Underneath, at the exit end of the carb (engine side). It is a right SOB to get at. Make a mini flat head screw driver to do the specific job. Or, as I have, buy the Jitsie air screw. Don't over torque the screw down. Note if you are removing the jet there is a mico-mini-small oring in there! Edited July 21, 201115 yr by NZRalphy
July 22, 201115 yr thanks for your replies chaps will now have a word with my local yamaha dealer to see if he can supply any bits i need You want to start here: Pilot jet: 22.5 Main jet: 130 to 135 Air screw: 2 3/8 turns out Needle clip: 2nd slot down from the top (thick washer below clip and thin washer above)
October 3, 201313 yr "I recall it is a Mikuni 28mm BSR SE..." Is that the same carb as the one used on the EVO 4T? Edited October 3, 201313 yr by levis
October 9, 201313 yr By the way nzralphy, I saw you have replaced the pilot screw by an more handy Jitsie air srew. Do you have a link to buy It? Does this one fit: http://www.ebay.com/itm/MIKUNI-pilot-fuel-screw-604-26003-007-138-RS-smoothbore-TM36-TM40-/231041312076?pt=Motorcycles_Parts_Accessories&hash=item35cb22a54c&vxp=mtr Thanks Edited October 26, 201313 yr by levis
October 28, 201313 yr http://www.trialscentral.com/forums/topic/25302-beta-4t-jitsie-carb-screw/ http://www.trialendurodirect.com/products/Jitsie_Beta_REV4T_carburettor_air_screw_569.html http://www.trialendurodirect.com/index.php?manufacturers=39&sort=&filter=12
November 12, 201313 yr Thanks nzralphy,By the time you answered I had already bought this one:http://www.gprquad.c...5_1416-849.htmlIt fits well though a bit too long. I had to shorten it and now my carb is under control. yes! great stuff.By the way this one doesn't fit (too big):http://www.ebay.com/...b22a54c&vxp=mtr Edited May 10, 201412 yr by levis
