July 26, 201115 yr Hi, After abit of a look on the net for a new disc rotor for the front I have found the VEP wavey disc rotor, has anybody had any experience with these rotors? At £40 ish I think it might be worth a try, and then also change to a rear one when I get the chance..... Also, I am also in need for a brake master cylinder kit for an 09 evo, I have seen the clutch master cylinder kits on trials and tribulations : Clutch master cylinder kit Are these the same for both levers? so could I order that and fit it straight into the brake lever, I am assuming they are the same but I wanted to check first. Thanks Adam
July 26, 201115 yr Hi, After abit of a look on the net for a new disc rotor for the front I have found the VEP wavey disc rotor, has anybody had any experience with these rotors? At Edited July 26, 201115 yr by pedronicman
July 29, 201115 yr Author Well I have ordered the VEP discs today, let's hope they turn up soon! Deffinately going to look a little different to standard! As for the master cylinder kit I managed to get it from Haven Trialsport and after lookIng in the parts book it does seem to be the same as the clutch master cylinder! Adam
August 3, 201115 yr I also use the VEP discs and have done for a few years now. I have a Factory 300 Beta and found that the discs are as good if not better then the original discs and don't forget that they look nice too. I can't see you having any issues with them.
