fantic forks
anybody know if 301 chrome stantions and all the internal gubbins will fit into 240 bottom legs ???
Thats what I put in mine, You can also make a triangle shaped plate that bolts onto the 241 fork disc mounts and the brakeplate. Saves you splitting the forks. Also I used the 241 top fork clamp to move the bars forward. It just needs a bit of a shim making out of thin plate for the clamp.
