Need fuel/air needle for beta rev 4t
Noticed my fuel air needle was broken. Tried to order a new one from Lewis sport and they have to get it from the factory and the factory is closed for a month.
Anybody have a line on athis part for a 2008 beta rev 4rt.
Thanks!
Are you asking for the fuel screw on the bottom of the carb ?
The same carb is used by Yamaha on a couple of models.... ask the Yam man to see if he can help.
Edited by NZRalphy
Have a stock one, but I think you want one you can reach with your fingers. I believe the yamaha 660 uses the same type carb if you do a little searching you can locate the longer fuel screw or screws as that yamaha uses 2 carbs. The tip is a little shorter but works fine that is what I'm using. Like you are finding here in the U.S. is no jitsie fuel screws.
