Losing my faith
:wall: My scorpa has decided to come up with another problem its horsing out gear oil from breather pipe not a clue why???. Its a steady dip, started it up this morning after fitting my rad i had repaired by the time the fan kicked in there was a 12 inche puddle of oil on the floor i noticed i little oil on my right boot last time i was out but i had just changed the box oil so thought it was abit of excess but now i know thats not the case. I am just hoping it never got to hot last time i was out when the rad went it its damaged the motor some were. Someone please tell me its nothing to worry about or its a easy fix because and really running thin on faith for these scorpas after been told there bullet proof.
Any info would be most helpfull thanks Andy :thumbup:
I think the clue is in the just changed the box oil, what year and model are we talkin here ?
It's a 2004 sy 250 fella
how much oil did you put in it?? Did you remove the small bolt just under the kickstart and fill it until it starts coming out that hole?
