September 8, 201115 yr I have a long term project on the go at the moment a C15. Was up the shed tonight and done a dry build on the rolling chassis,seems like I will have to increase the ground clearance as its quite low about 9",not very good.The frame is standard, front forks are standard,What is the best length of rear shockers to fit to help with the ground clearance.As I said its a long term project as I'm enjoying riding my 250 Scorpa and learning every trial I do.Any other advice would be much appreciated. cheers the noo Brian
September 12, 201115 yr hi, this is my dads C15T which he got last year. it was standard and had the external sprung forks etc. As you say there isnt too much ground clearance so that was the main task in getting the bike ready. Initially we just replaced the front springs as there was quite a bit of sag in them. This didnt really help much and it was decided that the front forks would be replaced. We settled on MZ forks, not pre 65 but look the part especially when the seal holders are added and i think they were slightly longer than standard so helped again with ground clearance. Also i managed to get some alloy yokes to suit and these were added. We had the head angle altered slightly to tuck the wheel in which probably gave us a little extra ground clearance and the footrests dropped and moved back a little. I think the rear shock length is now 360mm, but will need to check. With the mods i think the bike now has around 12-13" of clearance. Before. After. (have since replaced rear shocks)
September 12, 201115 yr Author Cracking looking bike,if you could let me know the length of the shocks you used please cheers the noo Brian Edited September 13, 201115 yr by broony
September 13, 201115 yr very nice indeed, and as you say the forks look period.....can you remember what the yokes were off, and if they needed much to make them fit?
September 13, 201115 yr Hi The yokes were from ebay. They were made by a guy that sells a few cub bits( i have some on my honda too). i think they were about
September 26, 201115 yr Author Front end finished,looking to build a wheel for the rear, was wondering what width of rim to use? cheers the noo Brian
September 27, 201115 yr generaly the rear rim width is 1.85 inch, though some bikes use 2.15 inch. as you would still be using a 4 by 18 tyre i'm not sure what difference the wider rim would make to the tyre profile and therefore grip .....but the wider rim might make the tyre too "fat" for your swing arm, so i'm guessing you would be better with th 1.85 rim. there'll be a bunch of C15/B40 riders along any minute with their views i'm sure.
September 27, 201115 yr If you haven't bought anything yet go for the 1.85. If you need George Spence (the wheel builder)tel no just ask. He's at Cupar. Ross
October 8, 201115 yr Author Can anyone advise of the final drive for Alf my C15 trials project. cheers the noo Brian
October 9, 201115 yr For slow tight turns, 428 with 13/72 seems OK with an 18 tooth engine sprocket. You can get the 18t engine sprocket here, see details re engine casing ! http://www.trialsbits.co.uk/product_info.php?cPath=85_182_257&products_id=689 Incidentally I use 15 / 62 with 428 chain on the B40, some clever person will be able to work out if its the same as 13 / 72. But has the advantage of a slightly smaller rear sprocket for clearance. Ross
October 9, 201115 yr You can get the 18t engine sprocket here, see details re engine casing ! http://www.trialsbits.co.uk/product_info.php?cPath=85_182_257&products_id=689 Incidentally I use 15 / 62 with 428 chain on the B40, some clever person will be able to work out if its the same as 13 / 72. But has the advantage of a slightly smaller rear sprocket for clearance. Ross hi 15/62 is alot higher geared than 13/72
