September 23, 201115 yr Just got myself a new rear mudgaurd and sticker, however i suspect im only going to get one crack at applying said sticker. So is there a tried and tested way to get it right ?
September 23, 201115 yr Easy as this is how i was advised by me mate whom works at BMW uk body shop. I applied stickers following these instructions. Get bowl or bucket of warm soapy water washing liquid i use, soak the sticker in it for 2 minutes then wet the mudguard. Remove the backing of sticker nad a quick dip in water then apply to mudguard. You will be able to adjust and move the sticker into required location then with a damp clean cloth work the water out from the middle to the sides of the sticker, you may want to use a hairdryer to speed you the process, but dont over heat as it may strech the sticker if its thin. Best OF luck
September 23, 201115 yr Author Easy as this is how i was advised by me mate whom works at BMW uk body shop. I applied stickers following these instructions. Get bowl or bucket of warm soapy water washing liquid i use, soak the sticker in it for 2 minutes then wet the mudguard. Remove the backing of sticker nad a quick dip in water then apply to mudguard. You will be able to adjust and move the sticker into required location then with a damp clean cloth work the water out from the middle to the sides of the sticker, you may want to use a hairdryer to speed you the process, but dont over heat as it may strech the sticker if its thin. Best OF luck Cheers for that, tried it, and tbh it's not the best of jobs but it'll have to do
September 23, 201115 yr Cheers for that, tried it, and tbh it's not the best of jobs but it'll have to do Really ive done loads and allways had great results. Sorry if it didnt work out to well
