October 9, 201115 yr Hi All Just got hold of a Beta Evo 2010 125 for my son and we want to change the gear oil. Can anyone let me know if it is best to use Light Gear Oil or ATF and also how much should i put in. The specs say 550 ml but i see on the forums some people recomend less as it helps the clutch disengage better. Any thoughts or suggestions greatfully received. Geoff
October 9, 201115 yr In my 200 I use 450ml of Putoline light gear oil. It all works much better than when it had ATF in.
October 9, 201115 yr I'm running putoline gp10 as per John Lampkins reccomendation. I'm putting in 500ml. So far, so good! Hugh
