Lever will not disengage clutch
yellow_cad
Trying to clean up some of my cables on my 72 OSSA MAR. Had the clutch cable off and now the lever even with lots of movement on the clutch activating lever on the case will not disengage the clutch. It is like something is not correct with the clutch actuating rod. I believe there is a ball in there but not sure where it is or if it could have fallen out. Any thoughts would be appreciated.
Jim in Folsom, CA
