Flimsy kick starter - ty250 mono
He guys, got the ty250 mono running. One of the things I did was cleaned up and re-greased the kick starter. But now it wont sit nicely stowed away while riding - it just creeps out. Suggestions?
thanks
I assume you did not loose the detent ball. I had the same results with my ty350 mono which has a well worn kick starter. I tried setting it back on the shaft so it would be in a upright position so my short legs could access it easier but it made it want to swing out also. I had to move it forward so the weight of it would keep it in place. I also strechted the detent spring slightly to put more pressure on the ball.
Thats probably the issue....
