waggstar Posted January 9, 2012 Share Posted January 9, 2012 hello ive just bought 1987 ty250 i knew it was needing work but as you no when you get it home you start to see ahole lot more wrong with it the bad thing is the back wheel is knackerd the wheel was moving from side to side so i took off the tyre to see what i could do and to my horror the alloy was rotten so now i need a rim and spokes can anybody tell me where to go with this problem, cheers. Quote Link to comment Share on other sites More sharing options...
jaygee Posted January 9, 2012 Share Posted January 9, 2012 Afraid this is quite a common problem for the ty mono having only a 32 hole rim.Central wheel components can now supply a 32 hole morad tubeless rim however the spokes are not available from them which seems strange? A set can be purchased from yamaha[very expensive]. I have seen sets for sale on ebay but not recently for around Quote Link to comment Share on other sites More sharing options...
waggstar Posted January 9, 2012 Author Share Posted January 9, 2012 Afraid this is quite a common problem for the ty mono having only a 32 hole rim.Central wheel components can now supply a 32 hole morad tubeless rim however the spokes are not available from them which seems strange? A set can be purchased from yamaha[very expensive]. I have seen sets for sale on ebay but not recently for around Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 10, 2012 Share Posted January 10, 2012 Thanks for that info Jaygee looks like i could be looling at changing the wheel all together. Best bet is to change the wheels altogether. In the day a lot of us used Talon wheels but might be easier to get 2nd hand GG etc. Quote Link to comment Share on other sites More sharing options...
shedco Posted January 10, 2012 Share Posted January 10, 2012 (edited) Another option, SM Pro 32 hole 'normal' rim from central wheel, about £90. Have the old spokes re plated zinc or chrome. Just make sure when undoing the spokes you don't snap any ! Edited January 10, 2012 by shedco Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted January 10, 2012 Share Posted January 10, 2012 I tried to get a 32 hole tubeless rim from central wheel components (emailed one night whilst on net) and they said that they could not supply a 32 spoke tubeless rim ??? I am trying to build a tubeless wheel for my Majesty 175 and have been looking out for old gas gas wheels as apparently some of those are 32 spoke tubeles, anyone better informed ? Quote Link to comment Share on other sites More sharing options...
booma Posted January 10, 2012 Share Posted January 10, 2012 I tried to get a 32 hole tubeless rim from central wheel components (emailed one night whilst on net) and they said that they could not supply a 32 spoke tubeless rim ??? I am trying to build a tubeless wheel for my Majesty 175 and have been looking out for old gas gas wheels as apparently some of those are 32 spoke tubeles, anyone better informed ? I used a gasgas tubeless rear wheel for my ty175 but was using the original hub which is 36 spokes (see fun in the garage yam forum)Malc Simmons from Southern wheels is building Honda tlr hubs with excel tubeless rims, these rims have the flange in the middle like the montesa 4rt rear wheel, I assume you are using the mono rear hub with "Z" spokes Quote Link to comment Share on other sites More sharing options...
big_red_bike Posted January 10, 2012 Share Posted January 10, 2012 I tried to get a 32 hole tubeless rim from central wheel components (emailed one night whilst on net) and they said that they could not supply a 32 spoke tubeless rim ??? I am trying to build a tubeless wheel for my Majesty 175 and have been looking out for old gas gas wheels as apparently some of those are 32 spoke tubeles, anyone better informed ? Hi i think you have got it the wrong way round the early wheels were 36 hole and the new ones are 32.Its the 36 hole that are hard to find. Quote Link to comment Share on other sites More sharing options...
waggstar Posted January 10, 2012 Author Share Posted January 10, 2012 Another option, SM Pro 32 hole 'normal' rim from central wheel, about Quote Link to comment Share on other sites More sharing options...
waggstar Posted January 10, 2012 Author Share Posted January 10, 2012 I used a gasgas tubeless rear wheel for my ty175 but was using the original hub which is 36 spokes (see fun in the garage yam forum)Malc Simmons from Southern wheels is building Honda tlr hubs with excel tubeless rims, these rims have the flange in the middle like the montesa 4rt rear wheel, I assume you are using the mono rear hub with "Z" spokes yes its the mono rear hub with Z spokes il look into that form you said, i just didnt think it would be so hard to rectify should have left alone and just lived with the wobble thanks for the info anyway Booma. Quote Link to comment Share on other sites More sharing options...
shedco Posted January 10, 2012 Share Posted January 10, 2012 I have had the same problem with a front wheel. Got to the last spoke & snapped it. Ended up with a full new set of spokes, you cannot buy single spokes! An expensive lesson. I am now an expert in removing them! Quote Link to comment Share on other sites More sharing options...
