rock hopper Posted February 6, 2012 Share Posted February 6, 2012 Is the bolt on a tlr that holds flywheel right hand or left hand thread Thanks Quote Link to comment Share on other sites More sharing options...
noggin Posted February 6, 2012 Share Posted February 6, 2012 Hi mate, Def a right hand thread. On one the XL models you could use the rear wheel spindle as an extractor. Not sure on the TLR though. Quote Link to comment Share on other sites More sharing options...
sherpagorri Posted February 6, 2012 Share Posted February 6, 2012 Hi Rock Hopper, in the tl125 the bolt has a left hand thread, so to unscrew you must turn it anticlokwise, similar to the nut that holds the centrifugal oil filter. I Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted February 7, 2012 Share Posted February 7, 2012 Hi Rock Hopper, in the tl125 the bolt has a left hand thread, so to unscrew you must turn it anticlokwise, similar to the nut that holds the centrifugal oil filter. I Quote Link to comment Share on other sites More sharing options...
tlrider Posted February 7, 2012 Share Posted February 7, 2012 The retainingg bolt that holds the flywheel onto the shaft is right hand; the flywheel spins CCW while looking at it from the left side of the bike which will tighten a right hand thread as it spins. The threaded hole for the removal tool I believe is left hand. Quote Link to comment Share on other sites More sharing options...
