pheonix_tat Posted February 14, 2012 Share Posted February 14, 2012 I have read a thread about using an RD200 kick start on a TY175. I bought one and it does work although the kickstart boss is set at an angle reducing the kick stroke. The splines on the boss are shot so it needs replacing. The RD kickstart appears heavy duty. My question is, if I by a new TY boss will the RD kickstart lever fit on (i.e. the lug with the circlip at the top)? I know the RD level may need a bit of bending etc. I need a new assembly to work. The TY boss is around Quote Link to comment Share on other sites More sharing options...
bruno21 Posted February 14, 2012 Share Posted February 14, 2012 I have tried various kick starts but the original works the best,all the others like you say are at the wrong angle and need fabrication to make right, keep looking on Ebay I have just picked a complete one up for Quote Link to comment Share on other sites More sharing options...
tee_why Posted February 15, 2012 Share Posted February 15, 2012 I tried one off a RD350, its longer, heavier, and teds to fall back, and worst of all that when standing on pegs, it hits you knee! Only good part about it, the design in the pivot shaft is better than the TY175 one. I heat bent mine to try and clear after market pegs, ended up going back to a new TY one. Quote Link to comment Share on other sites More sharing options...
mattylad Posted February 16, 2012 Share Posted February 16, 2012 Similar story, went back to the TY one in the end Quote Link to comment Share on other sites More sharing options...
