mill9898 Posted February 16, 2012 Share Posted February 16, 2012 is it just the same procedeure as bleeding the brakes ? and how do i tell if my bike uses lhm fluid or brake fluid ? as the res cap is an after market one? the bike is 08 Quote Link to comment Share on other sites More sharing options...
lee99780 Posted February 16, 2012 Share Posted February 16, 2012 I might be wrong and I'm sure someone will tell me but I think lhm is green Quote Link to comment Share on other sites More sharing options...
nigel28 Posted February 16, 2012 Share Posted February 16, 2012 (edited) Hi mate yes 05 onwards uses mineral oil in the clutch.and as far as bleeding you must always back bleed a clutch on a gas gas you will need to take the top of the slave make sure oil is low as when you force the oil back it will fill up, use a shringe with a piece of rubber hose on so it will fit on the bleed screw open bleed screw force oil back up to the top hope this helps mate. Edited February 16, 2012 by nigel28 Quote Link to comment Share on other sites More sharing options...
