scorpa 4 dean Posted July 29, 2012 Share Posted July 29, 2012 Can anyone tell me what problems are caused on the Beta Rev 3 if the head gasket has. Trying to eliminate a few problems with mine. Quote Link to comment Share on other sites More sharing options...
scorpa 4 dean Posted July 29, 2012 Author Share Posted July 29, 2012 Meant to say if the head gasket has gone. Quote Link to comment Share on other sites More sharing options...
pindie Posted July 29, 2012 Share Posted July 29, 2012 I suppose it could pressurise the coolant? Have you searched on hear for it? Or trials bike in general.... Quote Link to comment Share on other sites More sharing options...
0007 Posted July 29, 2012 Share Posted July 29, 2012 One of 3 things happens 1 You get engine compression leaking into the cooling jacket, this will blow coolant if excessive and you will also get oil and carbon etc in the coolant,, usually pretty obvious 2 Coolant leaks into the combustion chamber, this means low coolant and white smoke from the exhaust, also condensation on the plug and combustion chamber when the engine is cold 3 Simply a weeping gasket that pushes coolant out and dribbles it down the cylinder If its possible to pressure test the cooling system always do it when the engine is hot, there is a lot of thermal expansion and it happens at different rates as the engine warms, there may be no problems when the engine is cold Quote Link to comment Share on other sites More sharing options...
scorpa 4 dean Posted July 29, 2012 Author Share Posted July 29, 2012 To resolve my problem i think the answer is to change the head gasket anyway and check and change all oil seals also change the radiator cap incase the pressure release is not working and also flush the oil and cooling system to remove any unwanted debris. Fingers crossed thats all i need from a bike that was bought 2 days ago. Thanks for the help very much appreciated Quote Link to comment Share on other sites More sharing options...
