Throttle Bearing
Hi I was looking on trials uk and they had a throttle bearing that comes on the Adam raga gas gas. I would really like a light and easy throttle.
Would this make much difference?
Thanks
Ben
Yes it does, but if your comparing it to the Raga bike, you will need the light spring in the Keihin as well to match it.
For free you can oil you handlebar under the twistgrip, makes an amazing difference
Totally different designs - so im not sure if it would work. If you want a lighter spring in the Dellorto, You can sand down the sides of the spring a bit to decrease the wire diameter.
