September 19, 201214 yr what colour should be on the bike. the colour on it is yellow. i'm 16 stone and the suspension is soft
September 19, 201214 yr what colour should be on the bike. the colour on it is yellow. i'm 16 stone and the suspension is soft At 16 stone (224 lbs) you may want to consider a heavier spring. If you are a new rider and havent developed the "unweighting technique" the stock spring will be a problem. I'm a little over 14 stone and don't have a problem with the stock spring but I've learned to not overwork the suspension and absorb the bumpy stuff with my legs. If you are coming over to a Trials bike from the bigger off-road bikes, the suspension will seem too soft at first. Jon
