bondy Posted November 11, 2012 Share Posted November 11, 2012 hi all what gear box oil are you guys useing? or whats the best to use? Quote Link to comment Share on other sites More sharing options...
sherco34 Posted November 11, 2012 Share Posted November 11, 2012 Castrol ATF works well in my sherco, not that expensive too Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 11, 2012 Share Posted November 11, 2012 motul transoil seems ok got it with a service kit i usually use putoline light gear oil which i have never had a problem with Quote Link to comment Share on other sites More sharing options...
dadof2 Posted November 12, 2012 Share Posted November 12, 2012 If its for your 350 Sherpa use EP 75-90 in the gearbox and ATF or 10w30 in the primary drive. Cheers Quote Link to comment Share on other sites More sharing options...
dadof2 Posted November 12, 2012 Share Posted November 12, 2012 Similar topic but no for Bulto. In general ATF is too light for trial bike hearboxes - I know people use it but that does not mean it is right. ATF is about SAE 10 Most gerboxes need a SAE 20 or 40 when hot so use something like 10w40 or 20w-40 or a proper gear oil as recommended by Putoline. Cheers Quote Link to comment Share on other sites More sharing options...
bondy Posted November 12, 2012 Author Share Posted November 12, 2012 cheers guys Quote Link to comment Share on other sites More sharing options...
