November 13, 201214 yr Hi ive just got an 98 250 techno and have a couple of questions that i did'nt ask the previous owner. What oil ratio do i mix with a 5 litre can of petrol? What position should the petrol tap be for on off and reserve? Thanks in advance, will probably have another twenty questions before the end of the week! Andy.
November 14, 201214 yr i've a 1999 so could be close i run 50:1 for years, no problems ie 1 notch of a 1L bottle of oil, some nice - ipone? - bottle have special measuring thing. there was a pdf/spreadsheet posted here years ago with all the measurements broken down in easy to know sizes also check out this site - http://www.trialsport.com.au/beta/documents.htm - loads of parts diagrams and manuals for beta (top work to they guys who made that site) fuel - if i recall correctly, forward (towards bars) is off, sidewards is on and backwards (towards rear wheel) is reserve
November 14, 201214 yr Author Thanks Rabie, what things do i need to watch for with these bikes as i have never had a trials bike before. What pressures do you have the tyres at? Do you use super unleaded? Andy.
