November 20, 201214 yr Hello Ive managed to snap off the choke lever mount off the magura clutch master cylinder on my 125 scorpa four stroke any Ideas as to where I can buy a new one as all i can find are the whole master cylinders at 150 pounds a bit steep as i only need the cover or would anyone know if any other models may fit Husaberg and ktm types with the hot start lever look similar but dont want to buy if they differ, Thanks John.
November 21, 201214 yr I would just mount a lever on the bars or somewhere on the frame and run the cable to it. Or something like this. http://www.adrenalin-pedstop.co.uk/p-Domino_manual_choke_lever_for_handlebar_mounting_-5146.aspx?gclid=CP3as8TR4LMCFSHHtAodNEAA2Q
November 22, 201214 yr Mine broke too so I attached a nylon loop to the nipple on the end of the cable and I just pull that when I start from cold. I think the magura clutch is the same as the ones on the KTM's as I've bought replacement levers for KTM's and they fit perfect (and are cheaper)
November 27, 201213 yr I bought them off ebay, just did a search on magura clutch lever and compared to the original. Pretty sure its the one with the integrated adjuster
