November 25, 201213 yr Can anyone please advise me if there is an idol flexi adjuster available for a Keihin PWK 28 . The carb needs to be adjusted on the left hand side as per Gas Gas / Sherco, Jotagas, my carb has the air screw on the left and the idol adjuster on the right ( impossible to reach ) I know you can buy an air screw flexi adjuster for Beta's but can not find anything for an idol adjuster.
November 26, 201213 yr Have a look on the splatshop site at what they do on Keihins & drill the adjuster on the correct side, from memory the thread is a standard size so you can use a short screw to blank off the hole on the other side
November 26, 201213 yr Author Thanks Tony27, I have seen Splashops site, it was our mechanic that suggested a flex adjuster before getting the drill and taps out, so far all I've found are flexi adjusters for the air screw though, honestly would have thought there would be a product about but there isn't ..... time to make some I think !
