Sherco Mods
Hi guys, I am looking for some good mods for my sherco 125 2008, any ideas?
Hi
assuming that we are talking about performance rather than bling (i hope so), bit of a boring but practical response:-
  • Flatslide carb (Keihin or Dellorto VHST)
  • Jetting spot on.
  • New piston rings.
  • Set the squish (piston to cyl head) to a performance oriented value.
  • Decent rear shock (ohlins, TRP etc.)
  • Shock spring to suit your weight.
  • Clutch basket replaced if worn
Dom
Insure everything works properly, then put the best rider you can find on top! :madnoel:
Thanks for the suggestions guys, I will try my best! :madnoel:
48t rear sprocket is one of the best mods to make.
For the standard carb 38 pilot-112 main worked good for us.
