Montesa Cota 348 Wheels
Can anybody tell me if other cota models spindles/wheels will fit cota 348. Just got some forks for a project and have no experience with Montesas.
Cheers
Rear spindle is the same as a 349. The front will depend on the yokes as some have a narrow yoke set up so cota123/200 should fit, but wide yokes will be the same as a 349.
Thanks for the reply jimbo349. Just measured the distance between spindle holes which is approx 120mm,
Would that wide or narrow?
Cheers
247 front wheel is the same as 348 but 247 backing plate is different to 348 and brake arm may not clear 348 slider. 349 fork sliders are the same as 348.
Thanks for the info feetupfun, thats great.
Cheers
